28.2 Astra Channel 4 HD problem (Denmark)
Dergolf
Maximal Sat Receiver FTA, 110 cm offset disk at 28.2 Astra
Denmark, West
Greetings from Denmark. I’m trying to se Formel 1 on 28.2 Channel 4 HD.
I’m trying to recieve Channel 4 HD on 28.2 ASTRA on my 110 cm offset dish. I’m in Denmark. I use an Universal LNB. I recieve a lot of channels but none in the lower frequensy range (Channel 4 HD should be on:
Frequenz:
10.936 MHz
Polarisation:
Vertikal
Symbolrate:
23.000 kSym/s
FEC:
3/4
Any tips, suggestions?
Have a nice day….
There are other frequencies. Try the Scottish one .kingofsat says Résultats de la recherche - KingOfSat
56U.K.DVB-S28PSK23000 3/450.1 Mb/s
[td]10936.00[/td][td]V[/td]
but also
27U.K.DVB-S28PSK27500 2/353.2 Mb/s
[td]12226.50[/td][td]H[/td]
34U.K.DVB-S28PSK27500 2/353.2 Mb/s
[td]12363.00[/td][td]V[/td]
1 of these may work better. try them!!
Dergolf,
You are trying to receive the UK beam of 28E which doesn't cover Denmark. A possible alternative way to receive Channel 4HD in Denmark is by pointing your dish at 15W. The BBC Satback signal is there on a North Sea beam. I use my GT Combo for BBC Satback and Channel 4 HD comes through well.
SimonE
Dergolf,
SimonE
I get Channel4 HD in Sweden 10936V Denmark should be OK.
but also
Thanks, i will try that. BTW I saw somewhere during googling, that Channel 4 HD is closed since july 2024. Is this only for the 10936 frequency or the channel in generel?
Have you seen the channel lately? I saw somewhere during googling, that Channel 4 HD is closed since july 2024. Sincerely….Michael
Dergolf,
SimonE
Many years 10-15 years ago i also had a 110 cm dish here in West Denmark. I saw a lot of english channel. I think it was BBC or ITV who transmitted Formel 1 that time. FTA. With my current setup, i get a lot of FTA 28.2E channels, and also a lot of coded Sky Channels, but the FTA Channel 4 HD is not one of them. But i will keep in mind to try the 15W position….sincerely….Michael
but also
Thanks. The top one you mentioned is the one that i not can lock on to. The other two…i will give them a try…. Thanks! Sincerely….Michael
If I remember correctly, I think there is a bit of a null running through Denmark.
Back when Astra 2E and 2F first launched Analoguesat made some reception reports here:
The results don't look great (pin = no reception) for Denmark.
It's not perfect at this moment,cloudy and very humid, but will probably be better later
