40E Express AM7
OK, thanks. Maybe if I waited they would appear in time.
Some more Txp active.
Look likes R are a lot stronger, same beam ?
Note - I've now moved the later posts with found C-Band transponders from Express AM7 40E in the Satellite Launches and Retirements section, as it can now be considered a working satellite with confirmed C-Band TPs.
Found KU Band TP's on AM7 can continue to be posted in the former section, but another thread for AM7 40E in Fringe Reception Reports will be added in due course.
AM7 40E in Fringe Reception Reports added.
Another GTRK added
GTRK Orenburg ..
encrypted
3582R 2896
That makes a total of 5 for me..
GTRK Orenburg
GTRK Elista 3590R 2896 enc
GTRK Vainash 3566R 2896 enc
GTRK Dagestan 2558R 2896 enc
GTRK Volograd 2578R 2904 enc
Also
RTPC Komi 3570R 2905 enc
RGVK Dagestan 3562R 2904 fta
as well as the mux @ 3676R 33483
I did also lock very briefly this morning a possible H feed ??
Labelled T2-M1-0 ..
feq 3552 ..
no SR sadly ...as the F15 just dumped it in memory as 45000
Second scan ..it had vanished ?
rgds
VS
IS THIS OK ?
[SATTYPE]
1=0400
2=C-Band Express AM7
3=3
4=5150
5=0
6=0
[DVB]
0=24
1=3543,H,2904,34,1,|-55 dBm, 4.3 dB
2=3543,V,2904,34,1,|-55 dBm, 3.9 dB
3=3557,H,2895,78,1,|-53 dBm, -10 dB
4=3557,V,2895,12,1,|-53 dBm, -10 dB
5=3561,H,2904,34,1,|-51 dBm, 5.8 dB
6=3561,V,2904,34,1,|-51 dBm, 5.6 dB
7=3565,H,2895,34,1,|-50 dBm, 5.8 dB
8=3565,V,2895,34,1,|-50 dBm, 5.8 dB
9=3569,V,2904,34,1,|-50 dBm, 6.8 dB
10=3569,H,2904,34,1,|-50 dBm, 7.4 dB
11=3577,H,2904,34,1,|-50 dBm, 5.6 dB
12=3577,V,2904,34,1,|-50 dBm, 5.6 dB
13=3581,H,2895,34,1,|-50 dBm, 7.8 dB
14=3581,V,2895,34,1,|-50 dBm, 7.3 dB
15=3585,H,2904,34,1,|-50 dBm, 6.9 dB
16=3585,V,2904,34,1,|-50 dBm, 6.9 dB
17=3589,H,2895,34,1,|-49 dBm, 6.9 dB
18=3589,V,2895,34,1,|-49 dBm, 7.3 dB
19=3615,V,14990,34,6,|-47 dBm, 6.7 dB
20=3615,H,14990,34,6,|-48 dBm, 6.6 dB
21=3635,H,15280,34,6,|-46 dBm, 7.1 dB
22=3635,V,15280,34,6,|-47 dBm, 7.2 dB
23=3675,V,33480,78,1,|-45 dBm, 8.2 dB
24=3675,H,33480,78,1,|-44 dBm, 8.4 dB
So ..another Encrypted GTRK ..
GTRK Udmurtia ..wherever that is ..
3586R 2805
and
Planeta-1
3544R 2905 which is fta
I notice Chris has them as Linear in his list above ..
Why R U scanning in linear mode Chris ?
you'll reduce sig levels possibly below lock ..
All currently receivable C band channels (on a moderate sized dish) from this bird are RHCP ..and running in linear mode will reduce the signal by approx 3db ..and produce LCHP 'ghost' signals that don't really exist..
3586R 2805
and
Planeta-1
All currently receivable C band channels from this bird a RHCP ..and running in linear mode will reduce the signal by approx 3db ..and produce LCHP 'ghost' signals that don't really exist..
Yeah I have just noticed the H+V.
I only have L+R on the gibertini as it has the rain cover on it.
Get yourself one of those ASDA brand lock lid food containers Llew discovered ..
A perfect fit for offset Cband feeds ..and the lid being removeable allows for easy depolariser plate insertion/removal
Might have to take a trip up there. :-)
SWMBO has said Im not needed up the allotment this weekend so Im hoping to pull the spare 80cm dish out from under the hedge and stick the c-band lnb on for a bit of fun.
I've a feeling you are gonna need something a little bigger buddy ..
I'd suggest a min size of 1 or 1.2Mtr ..
Got anything suitable ?
