Gladstones
- Zone 2 Fixed at Astra 2
Gibertini XP 75 cm fixed at 30 west
Gibertini XP 1 meter motorised 53e to 27.5w
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
- Midlothian
Done this support dish stayed perfectly aligned during high winds 3 days agoIf you could add a stabiliser from the wall to just above the motor at the top of the "mast", that would make the whole arrangement more solid - maybe use the same sort of bracket that is already fixed to the wall, but inverted and mounted so that the "upstand is very close to the mast above the motor and then clamp the two together (you'd probably have to shorten the upstand on the new bracket though)
