stephan94
Specialist Contributor
- 1.80 Channel master 5 LNB KU KA C Band ,Dr HD D15
Openbox S3 HD II, SR 200 Extreme 4K; GTmedia V9 prime ; TBS 6983
- Bavaria
yes. importunately sattelite dish and receivers and other equipment's are banned according to parliament law date back 30 years ago. despite these restrictions many homes have satellite dish and even in rural regions its rate is high.Are satellite dishes still banned in Iran?
Yes, but only the beams that cover the UK.Will I get this sat on a 65cm dish in the Midlands?
And probably only if the dish is pointed directly at 52E and so you are not trying to get it on an offset LNB.Yes, but only the beams that cover the UK.
I'll be fixing it there. Just thought i'd check to see if I was wasting my before starting.And probably only if the dish is pointed directly at 52E and so you are not trying to get it on an offset LNB.
In that context I have a no-name 70cm dish in W. London that is pointed at 46E with an offset LNB for 52E (and another on the opposite side for 42E) & using the 16-1 DiSEqC switch which handles the fixed dishes feeds, but the 70cm dish only gets a smallish selection of the stronger 52E channels as compared with when I use the 1.2m Gibby pointed directly at that sat. Setting the LNBs on the 70cm is a bit of a pig of a job, especially the one for 52E!
It's the sports channels on 52e I am looking at.If you peak on 51.5°E there are some FTA channels on the Europe beam but they're much more marginal than 52°E (especially 11290H). The Turkmensat transponders should still be receivable.
12303V is an easy catch on a zone 2 Sky dish here.One is on the west beam 12303v though.
Be aware the quality is pretty poorIt's the sports channels on 52e I am looking at.
It seems the east beam should be easy.
Might be receiver/video decoder specific as I've never seen this happen.Turkmen Sport hasnt worked properly for months - it runs "slow" then drops frames to catch up. Its REALLY annoying after a bit!
Had a little play with my Triax TD65 and got it quite easily……after farting about with the TD’s nasty elevation bracket.Be aware the quality is pretty poor
They are pirating web feeds so buffering on screen is common. Or frozen screens. Or drop outs for long periods of time. The streams used switch week to week so one week you might get the F1 in English with Martin Brundle, the next race its Italian of German commentary!
They make last minute changes about whats being shown - including chopping the end off events to switch to different sports.
