57E (NSS 12)
DXers might want to try using smaller antennas today. The 11165 H has extremely strong reception today
From here, nothing on this beam :(
2.20m seems to be the minimum in my area
I thought yesterday that 10984 H,45000 had left the satellite, but today I see that it is active, of course with a weaker signal than 11164 H, which remained at the same level.
The SPTV minipacket on 11049 H,4000 has a signal on the feed, when it locks, when it disappears.
Here's what I found on the Data transponders, the ones I could lock.
Today the 1110 H 45000 has been just about possible for a long time.
SES Demo
11165 H 45000 5/6 DVB-S2/QPSK
East Africa Beam
NSS-12 @ 57° E
NSS-12 at 57.0E is, I think, one of the most interesting satellites for enthusiasts. It has three spots over three major regions outside Europe: Central Asia, ME and East Africa.
The signal from the three beams are unequal in strength in my area, all the more so as I receive it with a small 1.50m antenna. The strongest is from the Middle East, more in the upper band, and 11400-11700 MHz, if I'm not mistaken, but the most interesting are Central Asia and East Africa, which have programs and feeds.
At some point the two beams overlap in my area, affecting the reception of one or the other, such as at 11544 H,51418 (Central Asia) and 11544 H,4500 (East Africa). For this reason, most of the time, the transponders cannot be found auto, but possibly manually.
I wonder what happens when the signal on both these transponders can be found with larger antennas. For example, DX Süvi, aka DX Bozóth, with his big antennas picks up the Central Asian mux, but I don't know how he picks up the East African one. This would be interesting to know.
I think there are other active transponders in the ME area that I can't find because of terrestrial interference between, 11500-1600 MHz.
In the upper band, I have noticed that there are more transponders than you see on the spectrum. This time a bigger antenna would make a difference. They are coming from the ME beam, but to lock them you need a S2X extension device.
Lately 11165 H,45000, 3/4, on East Africa spot, has been getting good signal that it can be lock it. I think it's not an accident that it can be locked, since with 6909x I received it with Crazyscan (Windows) and neumoDVB (Linux).
And as those who use stid135(6903x/6909x) cards know, locking a weak signal (but not only) is a problem. It's a kind of signal test for those who want to receive this mux and the others from this position.
11544 H,51418,1/4,S2- not new (possibly in S2X), CA beam, reported by DX Süvi,
11597 V,13332,9/20,(S2X)-Data, ME beam, new,
12654 H,3154,1/2,S2-Data, ME beam, new.
How's that working in your zone?
my scan
12648 H,0750,1/4,S2-Data, new(probably in S2X-RollOff: 0.05)
Scan with card 6909x in the upper band.
10998 H,2401,1/2-Data
10985 H and 11165 H with 2,20m have good reception
Here's what I found this time at 57.0E.
At 10984 H, we have more TV channels than the last time I searched for them.
Here's my scan. The 11604 H has become significantly stronger recently. We'll see when the lock is lifted.
11053 H 30000 DVBS2/QPSK 3/4 Central Asia Beam
11604 H 45000 DVBS2/QPSK 5/6 East Africa Beam
i must a little bit wait for a good signal
