57E (NSS 12)
Qellat should also go, maybe needs play with exact MHz (small SR)
11139.5 V 2200 8PSK 5/6 14.0 dB AlMada
11181.0 V 2400 8PSK 5/6 13.5 dB AlMada (feed)
11184.3 V 1210 QPSK 3/4 14.0 dB Qellat
11186.5 V 2290 QPSK 3/4 9.5 dB Badinan
11189.0 V 1775 QPSK 3/4 13.0 dB Duhok
11191.0 V 1452 QPSK 3/4 13.0 dB Silemani
11460.5 H 3500 QPSK 2/3 7.5 dB SE TV
It's all a coincidence of course... :ph34r:
But since today, SE TV is no more on NSS-12.
Might still be on that 7° W transponder I mentioned yesterday, though (I can't look that far West).
"Southern TV" should be the one.
My 1st attempt at raising the dish to get 57 east ended in failure no signals beyond 53 east :(
It then took about 90 min to get the signals back up to the previous levels on 26E/21E/4W & 7W :eek:
Got there in the end so will have another try next week end :)
I need to secure the 2 poles better than this attempt when I used a mast motor clamp,
Currently the poles are joined by an aluminum tube & a steel tube banged in with a lump hammer :D So I will drill a couple of fixing holes for bolts in each tube on my next attempt,
Just need to make the join more secure the pole is plumb with a spirit level through 360 degrees
57E Central Asia beam 11617H Almata (or Gakku!?) and other "new" NAU (only pink screen). Also channel 7 (Sedmoi kanal new freq 11517H 2222). (please ignore sat on screengrabs. "Real" 57E in C-band use).
I have said in another post that I have swopped my Dishes round on the shed. My 100cm Orbital can now see as far as 57East.Not getting anything from 57East though.With the TD88 I had no problem getting DUHOC 57 East.Not getting it with the Orbital though.Spent a couple of hours fine tuning this morning getting good signals on most satellites. but no DUHOC.
Now I find that DUHOC has gone.
Apart from the fact. Where has it gone.I am still getting no reception from 57East.
Can someone point me to a recievable transponer in the UK if one exists
Yes getting that one|Jamie. I have changed the longtitude.From 1.7W to 1.6W getting transponders now.
TBS6925 100cm Dish.
I will have a look around the satellite belt to see if I can find Duhoc as it will probably be using the same keys in a more favorable location:)
........... but no DUHOC. Now I find that DUHOC has gone.
Yes, pain for me as well.....regularly saw my beloved Real Madrid on this channel. :mad:
Yes Real Madrid is my favorite Spanish club we lost Real Madrid tv on 9 east then it moved to 30 west now only available on Euro subs :(
Now we loose both of the channels they used to show RM games :mad:
