Gemini v4.3:
Technical Infos:
* Enigma of: 16.02.2008
* GCC 3.4.4 Original CVS
* Web Interface: 6.0.4-Expert
* Busybox 1.01
* Tuxtxt V1.99
* CIFS 1.44
Remotecontrol:
* BLUE - Blue Panel (BP)
* 2x BLUE - BP -> Extras/Settings
* YELLOW - Quick-Button (can be configured via BP)
* RED - EPG list for active channel
* 2x RED - EPG style menu
* GREEN - subservices
Addons:
* own Addon-Server via Internet
* adding additional functions via internet from the Gemini-Server and install them automaticly
* Personal Addon-Server can be used (configuration via /var/etc/useraddon.xml)
* Create your own Satellites.xml, which only contains the Satellites you realy need
Camd:
* Different Camd�s can be linked to channels/provider (Autocam)
* Changeing the name and settings via own menu.
* Creation of a 2nd socket (/tmp/cam1.socket)
Daemon / Server / Clients:
* Dreambox can be used as printserver (BP->Extras/Settings->Printer (LPD), FAQ can be found in the database
* Dropbear (SSH) now switchable (DM500 - DM7000: Standard->off)
* Upnp Client and Server (for DM500 - DM7000 must be installed from our Gemini-Server)
* Automount, for examples have a look at: /var/etc/automount.conf. Devices, NFS or CIFS will be automatically mounted. Ideally for DVD- or Net- Drives (Editor can be found in the BP)
* Inadyn (Daemon for different DYNDNS-Services)
* little Apache (HTTP-Server based on HTTPD)
* NFS-Server (based on the NFS-Kernel-Modules)
Infobar / OSD / Skin / Background-Pictures:
* Position of the Infobar can be changed without editing the skin files
* Provider, Frequencies, Symbolrate and FEC can be displayed in the Infobar (If the Skins matches this function)
* Display of EMM, ECM or "Expertinfos" are switchable
* Picon (displaying the Channel-Logo)
* Extensions for Skins (Thumbnails, 3D-Font, Pictures for Progressbar)
* Background picture can be turned off (Plasma - Fix)
* Backgroundpictures (Radio- and File Mode) can be used as Screensaver.
* Changing Bootlogo via menu ( 7020 only)
* Backgroundpictures and Bootlogos can be created, testet and used direct on the Box (out of JPG, BMP, GIF or PNG)
* Showing Onlinestatus when the Box is connected to the Internet (must be activated in Expert Menu -> Network)
Files / Devices
* Support for CDROM/DVD no matter using IDE or USB
* JPEG�s ca be rotated and dislaying of the EXIF-Tags (not DM500)
* Support for OGG/Vorbis
* Random function for MP3 and OGG/Vorbis
* Backup function
* 2 new root entries for music and pictures can be created in the filemenu (BP->Extras/Settings->Root-Entry)
* support for the bigger remotecontrol on 500 and 500+ (normaly shipped with 70XX/600pvr - activate on BP->Extras/Settings)
Extras:
* Dreamnetcast (shoutcast-player) with Streamripper (direct recording from server and coding into mp3�s)
* RSS und Weather Plugin (for 7000 and 500 you have to install it)
* System Info: Many extra box infos like HDD temprature, stream-rates (>=7000) or kernel-, memory- and prozessinfos.
* Own scipts can be started via Blue Panel
* Changing the recording parameters (extra before- and after- recording time, storage location and recover-function for your records)
* Additional EPG-functions (Dishnetwork, cache, storage location)
* Font and Libfribidi e.g. for arabic
* Quick-Button-Menu: Many extra features for the yellow button (e.g permanent clock in OSD, freeze Image, audio selection)
* alarm-clock with volume offset playing own WAV-Files
* Calander for iCalander format + reminder ( Supported by MAC, KDE, Thunderbird, Goole calander, Rainlendar...). Standard folder is /var/etc(ical
* Support for DreamDVD no matter wether a DVD-Drive is available or not
* New screenshot routines (have a look at the Webif)
* Search EPG of all channels for an Event or a String and set timers directly (press MENU in EPG window or go to BP -> Extras)
* EPG-Infos of all recorded movies can be showed without starting the record.
* eTorrent - a torrent client based on ctorrent. Can be managed completly over the OSD
* disable the TV - output while taking a recording, streaming a movie and manually (usefull for boxes with very low lan-speed)
* update system time via transponder or internet ( Protocol RFC868 )
New:
* EPG-Refresh Based on Enigma-Timers (BP->Extras, Beta)
* In the Information menu own matrix for network Devices
* create own weather.xml for your Country in RSS/Weather Addon
* Dreamnetcast now with Favorites administration
Fix + update:
* eMail-Checker und IMAP (Unread e-mails remain unread, problems with GMail)
* Pictures turn lasts only half as long, all formats ca now be rotated (rotate with < 0 > on your Remote Control)
* please see CVS
Interfaces WebIF:
_http://127.0.0.1/cgi-bin/GeminiInfo
_http://127.0.0.1/cgi-bin/StopCam?ZAHL (ZAHL = number of cam)
_http://127.0.0.1/cgi-bin/StartCam?ZAHL (ZAHL = number of cam)
_http://127.0.0.1/cgi-bin/InitCam
_http://127.0.0.1/cgi-bin/ResetCam
_http://127.0.0.1/cgi-bin/setKey?typ=STR&key=/elitedvb/str-test&val=blabla
_http://127.0.0.1/cgi-bin/getKey?typ=INT&key=/elitedvb/int-test
We'd like to thank everybody who paricipated in the "Gemini suggestion" thread. Unfortunatly many things can not be realized from our side.
This images doesn't contain any keys or softcams. Backups or other modified Images are not from us and won't be supported!
Recommendation:
If you don't install the Image in flash memory, the flash image shouldn't be of a old version. A swap file/partition (>= 16M
should be present
if several processes running in background.
Thanks a lot and have fun
Your Gemini-Team
