I have a tripod with a 76mm pole. It's been sandblasted and powdered with the white stuff - not the most heavy-duty thing in the world but it did fine for my 1.2m CM.
For4 almost all the CM 1.2 m dishes I installed (around 80), all motorised, I used a locally made tripod design, enabling easy vertical adjustments. Itds just the pole plus 2 side bars, 90 degrees to each other, L-type with adjustment slots opened on the ground portions.
After almost 25 years of service, none has lost orientation,despite many receiver changes.They were painted twice with grey paint.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
