Beli1910
- Gibertini 150 with diqec motor 90E -30W
Wave frontier t90 45E-5W
Triax 110-,motor
Laminas 1.8m and Laminas 120
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
- Sevnica 8290-Slovenija
Bravo stephan94. I'm glad you took the initiative to test. It will be interesting when you come to different conclusions and results between LNBs on different satellites, to decide which LNB will ultimately give the best results. In the end, you will simply compromise the results and leave the LNB that you think gives you the most of the signal on the Clark, which is important for you to lock or watch. There is simply no ideal LNB that would have all the good features of competing LNBs and the weaknesses of, for example, Ibu. It is interesting that while some LNBs give good results in some places, they also give worse results than the competition.
