Any one running dump 1090 willing to try an experiment?
  • Thread starter Thread starter Archive-8
  • Start date Start date
hi all, i see that some of you have really good coverages.
i feed data to flightaware, fr24, planefinder and adsbexchange . My max range is 235 NM and i would like to extend it..
My setup: Pro Stick Plus on a Raspberry PI 3B+ (with dump1090-fa) and Coaxial collinear antenna (16 elements).
Have you guys ever tried coaxial collinear antenna? if yes, how many elements is the best and giving the best coverage?Screen Shot 2020-05-25 at 17.42.45.jpg
I built a 12 element co-co originally. I think I shortened it to 8 elements after it got damaged in a storm a while back. I get well over 200 miles in my most favourable direction (outer ring is 200 miles - hills block south round to south east here.)
Now that updates for Windows 7 Have ceased I have re imaged my ZBox to Windows 10.For the last few weeks I have been using a raspberry pi 3 + for VRS.Hopefully you all are getting my datea alright.Not many aircraft Can you confirm that I am in a connected state on your systems.The reason that I ask is that on June 2. I loose my DDNS redirection.I do not want to be trying to sort two problems at the same time.
Yes still seeing your data - currently tracking 3 aircraft :)
I may be down for a while on Tuesday - work on the line
Thank goodness for that.I was dreading a problem with the pi.It took me a couple of months to get it working properly.
Then a month to work out how I did it.I have a image on three sd cards as backup.:)
Fine here ponti. Grand total of four in the merged feed ATM :D
The new router has finally arrrived so once the missus has finished her vc meeting I shall be swapping it over
If Ive got the port forwarding set up correctly you should be able to see my data again now
R
R
You're dead to me Ross. Are you still using the same dns address?
Still on the same no-ip dns @Llew If pontiend can see me then then Id guess things are still ok
Not seeing you here .Analoguesat.Your feed status is connecting.Not connected.
Oh sorry - my misunderstanding. Ok will have a look at the port forward setup
Corrected my last post I should say your feed status is connecting
Ok Ive found the problem (I think!)
Now Ivwe got to figure out how to fix it!
