As I mentioned some time ago, these Astra.TV channels are encrypted with Nagra.
Currently, a PCMCIA card is sold for connection to a CI slot (common interface). It's the PCMCIA card and the card integrated into one unit. I'll post photos again later.
You can only view one channel at a time. I mention this in case you're using it with a receiver that has multiple tuners, as it doesn't allow you to view and record any other channels.
It even causes problems if you try to use Picture-in-Picture (PiP); the image stutters.
If you tune to a free channel and one of these channels, the image stutters.
The receiver is now being advertised on the Astra.TV website.
The regional channels, be careful, if it doesn't change, you'll only see the ones in your area according to the postal code indicated in the contract, you've been warned.
Regional broadcasters:
12 - (FORTA)
EITB,
TV3,
TVG,
Canal Sur,
Telemadrid,
À Punt,
TVC,
CMMTV,
IB3 TV,
Aragón TV,
TPA7,
La7 (Murcia)
3 - (Public broadcasters not affiliated with FORTA) Televisión Melilla, Televisión Ceuta, Canal Extremadura
4 - (Private broadcasters ) TV Rioja, Popular TV Cantabria,
La 7 (Castilla y León), Navarra Televisión.
Note: Channels already included (
crossed out).
Como ya comente hace tiempo, estos canales de Astra.TV están encriptados en Nagra.
Actualmente se vende una PCMCIA para conectar a un slot CI (comun interface), es la PCMCI y la tarjeta, todo integrado en 1, al final pondré de nuevo fotos.
Solo se puede ver un canal, lo comento por si lo pones en un receptor con varios sintonizadores, no permite ver y grabar otro canal de ellos.
Incluso da problemas si intentas hacer PiP (pantalla en pantalla), la imagen va a tirones.
Si pones un canal libre y uno de estos canales, la imagen va a tirones.
Hoy ya se publicita en la web de Astra.TV el receptor.
Los canales autonómicos, cuidado, si no cambia, solo se ven los de tu zona según el código postal indicado en el contrato, avisado quedas.
Autonómicos:
12 - (FORTA)
EITB,
TV3,
TVG,
Canal Sur,
Telemadrid,
À Punt,
TVC,
CMMTV,
IB3 TV,
Aragón TV,
TPA7,
La7 (Murcia)
3 - (Públicos no FORTA) Televisión Melilla, Televisión Ceuta, Canal Extremadura
4 - (Privadas) TV Rioja, Popular TV Cantabria,
Nota.- Canales ya incluidos (
tachados).
Esta PCMCIA me la dejaron para hacer el chequeo./I was given this PCMCIA to do a check.
Si alguno se quiere reir, que escanee el codigo de barras./If anyone wants to laugh, let them scan the barcode.
SES Astra Website
www.astratv.es
