Astra 1N at 19.2E
a lot of apartment buildings in Spain send lower band V down the aerial cable
You mean community distribution/installation of satellite by (FI) intermediate frequency (the cheap one) made in buildings.
This is the Digital+/Channel+ and I inherit Movistar+.
PS: The Air Cable? to a cable down the street? In general, it has many requests. No.
Te refieres a distribución/instalación comunitaria de satelite por (FI) frecuencia intermedia (la barata) realizada en edificios.
Esta la realizo Digital+/Canal+ y heredo Movistar+.
PD: Lo del cable aereo? a un cable por la calle? en general tiene muchas pedidas. No.
Changes of the day 5-May-2026
A new channel for ORS in SD, we already have 2 channels, in Astra 19'2oE, TP3 / Frequency 11244 H 22000 5/6 DVB-S/QPSK.
Los cambios del día 5-Mayo-2026
Un nuevo canal para ORS en SD, ya tenemos 2 canales, en Astra 19'2ºE, TP3 /Frecuencia 11244 H 22000 5/6 DVB-S/QPSK.
Screenshot 2026-05-05 at 18-16-44 Pescas del día por esos cielos como esta de caliente el tem...webp
what is this ORS channel? Local Austrian?
Thank you,channels with no interest,religious stuff and 3rd rate shopping.
Have a good day!
Changes from the day 6-May-2026.
They add 2 data channels.
An hour later, a new TV channel is added, for the moment without video.
An hour later, they erase it.
The changes of the day 9-May-2026.
3 encrypted links in Biss
TV Belin again erases it.
PGA links are not now
:-toilet
The changes of the day 11-May-2026.
Only the first TEST TXP52 is HD, the other 3 are SD.
With this possible change.-
Baloncesto1 would be in HD and SD.
Baloncesto2 would be in SD and has no HD.
With an SD of unused changes.
10758 V 22000 2/3 DVB-S2/8PSK, only HD channels.
10788 V 22000 5/6 DVB-S/QPSK, only SD channels.
10979 V 22000 5/6 DVB-S/QPSK, only SD channels.
Today the U.S. PGA links returned. :-rofl2
PS: As mistakes are always allowed, I have no idea2 and every day less (joia memoria), but I am not the only one, luck.
Today unchanged 16-May 2026, only link of encrypted events in Biss.
The unnamed link at 11635 H 7200 DVB-S2/8PSK asks for more 80cm antenna, alerted remains.
This other is activated the encryption in Biss, but it is seen.
More technical links, some in Biss and Nagra, others in 4:2:2, a photo of the latter.
116470 V 7200 DVB-S2/8PSK. 4:2:2. streaming PC.
Changes from the day 18-May-2026
This guy is here Extremadura TV on AstraTV, 11229 V 22000 2/3 DVB-S2/8PSK
2 name update for Sky and 1 new DFB.TV channel on this frequency.
The changes of the day 22-May-2026.
Turned off the extra 2 tp in 11406V with the duplicate channels, they already only broadcast these channels in 10729V23500 DVB-S2/8PSK.
The rest of Astra.TV’s tp/frequency with its normal broadcasts.
In theory today they cut it, about 10:30 without a signal (as planned), but then he returned, :-doh verified around 12:00. :-rofl2
At 15:00 it does not emit again, we wait almost 1 hour do not be that I return before confirming that it is already off.
Already active the links of Friday.
Changes of the day 3-6-2026.
BetaDigital channel (.).
More changes.
Video and audio earrings, this means that normal satellite receivers don’t find them.
End of the tests, there is nothing left of these channels.
In 11739V 27500 3/4 there is only CNN Int, the rest already deleted.
The photo when I found them, but when checking the channels, they are no longer, at the moment I save these channels in case they return.
More changes today. June 3, 2026.
3 Channels that Change Name and 3 New Channels
Changes of the day 15-7-2026.
BetaDigital channel cleaning.
Changes of the day 16-7-2026.
BetaDigital cleaning
Screenshot 2026-07-17 at 03-01-14 Pescas del día por esos cielos como esta de caliente el tem...webp
