BBC - Radio 2 in the Park
Spc..
TeVii S2 Tuners + TBS S2X Tuners, 138cm Gibertini + 100cm + 85cm and 80cm backup dishes. Windows Server 2022 + Windows Server 2025.
Slovenia
Radio 2 in the Park
Radio 2 in the Park​
City Park, Stirling: Friday 11th - Sunday 13th September 2026
I think it will be on 16°E or 23.5°E
We have to scan it.
Here is the line up:
Last year 2025 it was on 16°E
Eutelsat 16°E | VERTICAL
12714.557 Mhz, 9999 KS, DVB-S2/8PSK, 3/4, 11.0 dB
Signal is very unstable, from 11dB to 0dB in 300ms.
I have zero clouds, zero winds.
It has to be wind at the event itself.
Wasnt looking earlier, but it seems OK now, is it still happening for you?
Here too clouds go by and take some signal.
Hmm Im seeing it go from 9.8db to 8.4db now, it is a bit wobbly.
Yes, it was having wobble when ABC were on, hovering around 9dB here. We have heavy clouds with rain on and off...
Its mostly stable now, but sometimes it drops 2-3dB
Just gone completely now
Iplayer feed is still up so I guess sat is a backup, I think it'll maybe come back up as a bigger 14000 SR feed for the BBC 2 feed in an hour
Yes it completely dropped out.
Here no reception too.
I was wondering why signal so weak on 2.3M antenna 16E.
Planning to use 3M antenna instead in future on 16E.
But no My fault.
BBC has huge problems this year with uplink on 16°E
If you cant see them on 2.3 meters then they have 0 signal.
Dunno what they're up to, there was an unmodulated signal for a while, then something at 5db i couldn't lock, now its back to absolutely nothing on the analyser.
Yes from the start of the even i had problems with signal.
I had zero wind zero clouds but still huge signal drops 3-5dB.
I am in the pure middle of 16°E beam (Slovenia) but still had problems from start:1789241608654.webp
A big signal came up on the scope for about 3 mins, disappeared then the feed came back for about a minute then dropped again. They must have some issues methinks
Like wise
