satellitedummy
- silvercrest sl65-panasonic 26" lcd
- cumbria
Hi Guys
And apologies for a dumb question,but
Could someone please advise the best way to connect my Dragon to a 26" Panasonic LCD TV.
I am presently connected from the SCART on the TD to SCART on TV (and this i believe accepts a direct RGB signal) but am confused by the Dragon outputs,currently selected output is RGB/CVBS on the Dragon.
I had read on an American forum that one guy was coming from the SCART on the DRagon with a SCART to 3 Phono plug cable using the composite video on the TV and the Dragon set to YUV/CVBS. I purchased a cable for this hook up but the picture is worse than the SCART to SCART set up.
I have also seen video converters that convert composite to RGB but as these are a bit pricey i would appreciate some advice before i purchase more gear that isn't going to help.
Many thanks in anticipation.
And apologies again for the dumb neewbie question.
Regards
Mekanik
Regards
Mekanik
I often have to check which Scart is which on my (too many) STB's.
