s-band
- 1.5m IRTE PF, Invacom SNF-031, TBS6983,
Various L, S, C, X & Ka bits. 1.2m S/X/Ku/Ka Prodelin on Az-El (being refurbished), 1.8m Precision PF with Bullseye Ku LNB or various C & X bits
- Essex
My turn at a spring cleaning sale. The C band LNBs have been replaced by external reference LNBs. They work fine with the cheap Aliexpress feeds and OMTs.
The Hughes kit was new but I then changed my mind regarding the system. It's band B not band D as per title. Ku bits came with some VSAT equipment bought for the feed.
All prices plus shipping ex UK
Norsat 3220 20K +/-10kHz 3.4-4.2GHz 5150MHz PLL LO
Used, very clean, doesn't look like it has been outside. £65
Patriot PAT3515 15K +/-25kHz 3.4-4.2GHz 5150MHz PLL LO
Used, a bit grubby with some rust residue from fixings, works OK. Originally bought to get a feed that was attached. £55
Hughes 19.7-20.2 LNB with diplexer, circular polariser & BUC ("turtle"). No Feed
New, unused, boxed although I've lost the internal packing. £35 (can ship without the "turtle" to save post costs)
NJRC 2573H 10.95-11.7GHz PLL LNB WR75 10.0GHz LO
Used but clean as it was inside a radome. £20
NJT5037F 14-14.5GHz 13.05GHz LO 3W BUC
Used, clean. £20
Used, clean. £20
