- A little less analogue, and a lot more crap.
- UK
Did you see which sections were moving ?
(I won't ask your pole girth)
I took a video to better show what's happening. I wonder if part of the wobble is the dish itself? It's much lighter than the CM so will be flimsier/more flexible...
Thanks John. Are the struts attached to the top motor bracket or the dish bracket itself?I had a similar problem on my 1.2 Gibby of dish flexing from the dish mounting bracket, fitted top bottom and side struts which cured that. just took a quick shot of the dish in nearly dark sky but you can see what i mean.
Err can't remember to be honest CJ, i'll have a better look at it tomorrow in daylight and report back
Looks like there's a view of the entire arc - especially being on the 1224 H-H motor.That looks high up @John Fortunately I recently had the opportunity to move my cm1.2 to ground mount. I didn't fancy having to get up ladders as I get older to adjust dish or motor
You must have really understanding neighbours. Mine have kittens every time I work on my dishes...Yep it is high up and yep it is a pain but i had no other option, i swear by the old saying "where's there's a will there's a way"
You should be able to feel any play in the geardrive itself, especially if there is a noise.I took a video to better show what's happening. I wonder if part of the wobble is the dish itself? It's much lighter than the CM so will be flimsier/more flexible...
Do you remember which bit cracked? The alloy shell is light but has no give at all, so I am not surprised that it just shattered. I was thinking of packing any tiny gaps with washers or similar material...As before I was surprised how little tightening was needed to fracture the clamping with mine, so didn't bother looking to repair.
I suspect that it's mostly aesthetic rather than it having an effect on stability... But every little helps?!Whilst tidier and compact, you will have to wait for a storm to see how stable the new gearbox is.
It was the casting that bolts to the post, tightening one the - six ? bolts.Do you remember which bit cracked? The alloy shell is light but has no give at all, so I am not surprised that it just shattered. I was thinking of packing any tiny gaps with washers or similar material...
You really should dig it out and get it restored....It was the casting that bolts to the post, tightening one the - six ? bolts.
I'm sure the box and motor is still here, unused/unloved.
Blimey @John, I didn't realise how much the dish itself contributes to the wobble.The back bracket on the 1.2 Gibby CJ is quite substantial so i made up a 3 way bracket to fix onto the back bracket for the extra dish rim edge supports - made an improvement to the stability of the reflector face for sure.
