Dodgy connections are more critical than sheer length (Within reason, of course)
I need to slow down the Jumbo motor, it's way too fast for this dish - had real control issues with the EZ2000 positioner. I need to try it with a normal Vbox and see what that's like with it, but it's likely I'll need some inline resistors to reduce the motor drive voltage. The EZ2000 also had issues recalling stored positions. I don't think it's mechanical - more that the 1224 produces far more pulses than a normal jack and it seems to have been reaching count limits at the extremes. Not sure....
I do have a smaller jack but I wouldn't be overly comfortable with it holding this dish, even though it was fine with the 1.5m Gibby, which weights about the same as this.The inclined orbit elevation jack is quite long, is it temporary and to be replaced with a 6" or 8" actuator?
Funnily enough, I do have a TM Vbox but it's without a remote and the operation seems erratic. Maybe I am using it wrong but when I press east/west buttons, it drives the motor for a couple of pulses and then stops. It then carries on. When I let go, it carries on for a second or stop before stopping.
It doesn't seem to work, even though it controls other Vboxes in the house. I connected my Alsat GBox one and that works very nicely with the 1224 - no miscounts so far and moving the dish at a more leisurely pace.CJ,
Have you tried using the remote control from the EZ2000 with your Technomate v-box? Sometimes they work, sometimes not. A factory reset of the v-box might also be worth a try?
So 58W to 53E is visible to me
Was messing about with a 1224 and technomate V box yesterday, as CJ says mine was erratic but the remote of the Moteck V box worked ok on it. The Alsat box worked perfectly with the 1224.CJ,
Stuck the two C band LNBs side by side until I get my LNB revolver but have lost my DiSEqC switch. Found a 2 port one, so only trying circulars for now.
Found 49E (14 BS transponders), 40E, 1W with AFN package on it coming in at 7dB ish. 11W strangely weak (7.5dbut all there. Haven't ventured further yet.
