CROSSBONES said:Yes it does fit with a little modification
You have to add some angle brackets to the bottom set
of bolts and also extend the threaded bar at the top.
I think scopous is the best person to ask as its his mod.
Was thinking about doing it my self.
I have a C/master 1.2m dish and polar mount here if you want too swap them for your 1224 mate?![]()
is there,a special adapter plate nesercary,between the polarmount,and the antenna,i have the 90 cm cm,but curencly not installed coz the polarmount was missing,now the system is complete i hope..
maybe still miss some parts?
to conect th emount,on the backside?
CROSSBONES said:Can you get hold of any more c/master polar mounts?;)
I can
Turok said:Hello Crossbones!
Good Morning!
now,after a long search,of 5 years i have found a used fibo 1,25 mount,but there was now screws includes,what type must i use?
also i have a new channel master mount,the size is here 9 cm,and fibo mount has 8,5 cm to fit it!
now,i diinstall my jager dual axis system,with gibertini mount that never works corectly,any always must use a . positioner for the western and eastern stalites,hope soon cold rainy weater will be ofer..
maybe i also try to install the channel master mount on the triax 1,40 m dish!
Turok said:Hello Olisun!
okay,no problem,i recharge my camera at the moment i measure it s.a.p.for you!
you only want the size of the adapter plate?
yes thoose parts,very expensice,i paid nearly 100€ each,coz shipping was aroung 40€ each item..very heavey the cm mount much more then the fibo,on the fibo mounts and channel master all screws are missing..
what type is exactly needed on each mount?
CROSSBONES said:Want to share your secret?;)
