butchyboy
- channel master 1.8m motorised on c band,ku band,1.2 metre prime focus irte dish, 1.85cm offset mabo dish,vu+duo & 42 HD lcd tv
- ireland
that would be great if you can nelsonIndeed you are correct @ozumo it is a steel insert /bush in the photo ... so long since i had one apart and took that photo , i had forgotten that ... the 1.8 is almost certainly the same i,m sure .. i will see if i can check that later without removing the bottom bolt , as the mount is in use ... maybe i can see if i take the nut and washer off ?
