Default language on channels.
smokin
none
United Kingdom
Is it possible to set the dreambox so english is always the chosen audio language instead of having to change it all the time when there are multiple choices ?
Depends on the setup
U have anything like Bullz text or Gsub working ?
If so 1. Set the both to English
or 2. Disabled them
There's a plugin:
addons > download > plugins > setup language 1.0
You can set your default language with this. Failing that use the audio quickbutton.
this can be done thru the web interface. Click Config, then Settings. There is an Audio Channels Priority thing there: "Specifies the priority of audio channels [...] When zapped to a tv channel, the audio channel (if available) will be selected with this priority."
To make English Audio of channel as default setting do this
1. Go to Web Interface (type ip of dreambox in your internet browser)
2. Click on Config
3. Then click on Settings
4. Find where there is Audio Channels Priority and paste this in box found just under
English#Englisch#dos#haa#qaa#org#ORY
5. Reboot from remote control
Don't understnad this Web Interfact setting. How do I get to this on the main menu? What do Ipress after Menu. Thanks.
Looks rather long winded. I will have a look when I have a moment. But, BTW is it possible to use IE to get to the Dreambox via IP address or does it have to be Firefox? Thanks.
IE will probably work as well - try it. If that sounds long winded perhaps a Dreambox isn't for you - it takes about 10 seconds.
updated with some more
English#Englisch#dos#haa#qaa#org#ORY#esl#Tonoption 2#Original#Audio_ORJ#Undetermined#
