DiseqC 2.0 not working on a DM500
chisparritas
nothing specila
Albacete
Hello,
long time reader here, this is my first post, I hope you can help...
I've got a DreamBox (flashed with OpenPli) connected to a DiseqC 2.0 switch which has astra19 on AA, hotbird on AB and astra28 on BA. the dreambox is configured using the default parameters for all the LNBs.
The problem is that both astra19 and hotbird work properly, but the dreambox does not find a valid signal from the astra28. If I switch the astra28 to the AA input on the Diseq it works fine, so I guess that the problem is on the DiseqC or in the DreamBox.
What am I doing wrong? What should I check to get this working?
Some people on other posts (and forums) suggest that the right DiseqC for the DM500 is a DiseqC 1.0 and not a DiseqC 2.0. Does it count? Is there anyone with a similar configuration like mine using a DM500 with a DiseqC 2.0?
thanks!
