Puzzling problem, this is.
Correct me if I'm summarizing wrong:
Both your receivers work perfectly on your shed installation.
On your house installation, the Blade works, the Iview doesn't.
The cable from house to the LNB has continuity. Maybe three ohms over estimated 150 milli-Amp for the LNB would mean 0.45 V voltage drop ~ not too bad.
You used the shed LNB (that worked there for the Iview) also on the house installation: No reception for Iview. That would also rule out LO-frequency drift of an LNB as compared to the loaded channel list, as that LNB worked at the shed.
As your suggestion, I'd check voltage at the cable end at the LNB now.
That means: cable connected to the Iview, loose at the LNB.
Then power up the Iview, and check voltage at the cable end. Should be about 13V for a vertical channel, about 18 volt for a horizontal value (plus at the core). (Don't create a short, while measuring!)
If there is 0 volt, it really is a connection problem.
If there is a voltage, alas this measurement at the LNB-end would better be done under load of the LNB. That is a bit more difficult to set up, if you don't have a T-splitter or so to split off the 'core connection'.
For the rest I cannot think of other possibilities to test, at the moment.
Why does the Blade work at the house, whereas the Iview does not...?
Greetz,
A33
