Dreambox 500 - JTAG Information
Guys,
I would appriciate you help on the previous question.
Thanks in advance.
Dont be so impatient. Not all our members log in every day - some of them only visit once a week, and some will no doubt still be on their summer holidays. This time of year you need to give it a month minimum before you start getting jumpy about a reply.
I used dm500aio jtag it said 100% complete but when i connect serial cable and use dreamup to load image it does not respond at all .any tips?
jben said:
Hi,
I have the same problem described in this forum. My DM500s is dead. I read several forums and I tried to upload a new image. I started to create a LPT cable and connect it to my DM500s (about 10 cm). Using jtag_windows and other jtag, I have the following error: Register Test Failed. Check cable connection.
I seen in some other forum that we can use DreamFlash for Windows v0.1
could someone give this tool (DreamFlash for Windows v0.1). Thanks for your help.
Does someone has any idea?
PS: I do not have tested using 100 ohms resistors yet.
Thanks.
100K are a must!
Have the same problem like zemogric and after flash with JTAG the green light is ON but the serial port is not accessible. I have already replaced the MAX 3243 with a new one but the same ;(. What else i can do to restore it ? Is there any way to flash the whole image with JTAG ?
The 100 Ohm resistors are soldered on the parallel socket, 3,4,5,6,and 11 then you connect your wires to these. Don't forget the insulation. If you use a shop brought Parallel Socket it will already have 18-25 shunted.
hi mate.which cam should i use to get premium contect.at the minute iam using astra 28degrees but i cant get the picture at all but i can get program info.please help
Do you have a subscription card? If so the cccam or oscam cams will read it.
hello all,i try jtag my dm500s with 3 times successfully.after dm500s gemini image upgrade .but no it still no red or green led light ,and it can't response to dreamup?
hi there,
any body post the DM500S WINDOW BASE J-TAG SOFTWAE I was unable to download any j-tag files from this site.
hopefully waiting for your reply.
thanks
hi, I am looking for this Software for JTAG "DreamFlash for Windows v0.1"
hope some one post this file.
thanks
You can get a DM500s for as little as £30 these days. It really isn't worth the hassle these days trying to repair such an outdated box.
You would be better off just throwing it away and buying a new one, or getting something better.
I appricate if you can help me for that little window base software, because I spend so many days on this box, I did soldering pins lot of mesh up in this box there after j-tag connection ok I got, so I want to see it come back to life again,
I tried with DOS, that is stuck in the middle saying "FLASH ERASE" then percentage shows 0%..., there after no progress , because INTEL unknown shows with alps tuner.
hopefully waiting for your help
thanks
thanks
The file you are wanting is quite easy to find follow this link.
https://www.google.co.uk/?gws_rd=ssl#q=dreamflash+for+windows+v0+1+download
" ................... other Search Engines are available ..................... " ;)
hi guys, I tried with this name "DreamFlash for Windows v0.1" in google search from last so many days, there are so many sites comes up but no where that file I found.
still I am looking for this file "DreamFlash for Windows v0.1"
