BornEvil
- TD78: multifeed with 9E, 13E, 19.2E, 23.5E. Sky Zone 1 @28.2E
- London
Hi guys,
I just moved house so need a pro to install my setup.
I required installation of a multi feed dish centred on 13e, with 4 LNBs. Pointing @ 9e, 13e, 19.2e and will try my luck with 0.8W. all with quad LNBs.
I already have most of the parts.
Will need to be installed about 7 meters high (2nd floor of townhouse), but easy access from a window, so may not require ladder (although I much preferred to install away from the window).
These are the parts I have already bought (all brand new):
Triax TD78
Triax multi LNB bracket
4x Quad LNBs 40mm, pretty thin (will replace 2 with Alps if required for 9e and 13e)
Loads of F connectors
Loads of Coax (7mm shotgun, already drilled and laid under floor when decorating).
So i still need supplying of 4x 8/1 Diseqc and a good wall mount.
Please email me price just for labour.
Triax TD78
