edit new entry point,for network search,not working on osn showbox?
Turok
1,25 Fibostop
Jäger Smr 1224 & Smo 36 Dual Axsis Motor
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Tagra 2,20 M Fullsize Dish
Echostar 2,40m Mesh for cband!
Austria
Hello!
after the satellite change today,my osn showbox loose all chanels,i make a complete factory reset,after sign up the language and hd 1080 screen mode,i see the nilesat transponder list,i go to nilesat number one transponder have a full signal,check also the hd channels with another receiver,got 10.6 db,so the signal is okay,but the showbox shows me,check your cable connection,i think the search now since the satelltie change,on a wrong freqency,and did not get the updated channel list from todays satellite change,when i press okay,when signal is here on nilesat transponder one,then i have only the option to go back in the menü,but,it will not find any channel,i try to edit manual a hd fregenca 11278 v,a normal hd receiver,show me signal,but under user define dvb s2 transponder it show me no signal,so what i have to do,and enter in the menu,setup entry point,that contain the channel list?
at the moment,when i press the menu button,nothing happens,until setup is complete..!
any ideas,i not have the manual booklet ,on the old satelltie was no prolem,but since august the signal is gone,since dvb s swtich up,no today it comes back,with the above problem,any ideas,what i can do,after one hour,still not find the new freqency out,that contains the new channel list,of atlantic bird 7!
thanks for information!
The AB7 frequency changes can be found here:
-http://www.eutelsat.com/home/AB4AAB7_DownFreq.pdf
and the OSN frequencies are here:
-http://www.flysat.com/osn.php
thanks,i enter the freqencys see the signal,but with the press of okay,iam unable,to start a serarch and leve the first setup menu,means,the freqency,that contains,the main information for all channels i still not find,also i found no posiblity for a manual search,very strange!
normaly it should detect like before the satellite change,same like the sky box seaching for new channels,but something wrong at the moment.!
