Fantastic tool Gold Master 525 combo
is that the version you have? what links are these?
Mine is still in its box!
ПО и расширения для GoldMaster SR-525HD
There may be others but I've not looked further.
Thanks for that Alex - here's the info off of mine ....
Is this still available on AliExpress to the UK anyone got a link
Looks like you can update that to a later version.
I gave up with Ali Express and splashed out on ebay. Ordered on Friday afternoon, delivered Tuesday - from Oman!
Is that from the seller on page one of this thread, £70 or someone else approx a month for del
thats who me @John @scopus used - very quick delivery from Oman
we knew and accepted we paid over the odds...
That appears to be the latest SW, or at least that's what Sky Doo sent me..
Took from off one of CJ's links and loaded in .. a little bit more recent but can't seem to spot anything more recent or from 2023.
Ordered, now to work out what to do with it
Yeah I'm a sucker for some new gadget to try out, checked them data images @lovelyperson not sure what am looking at,
Soi have never used a sat meter to setup my system before, always just used the sat finder on the e2 receiver. Considering I need to realign my dish hopefully I can work out how to use it
you'll need to add 1w into the receiver, remember to make sure to change LNB setting to universal when you add, add the strong aljezera TP - take the phone out with the RAMF app on outside, if on your network, on the app on wifi, it should say connected, choose satellite \ signal check, select 1w and the TP, and tweak your dish until you see the signal. boom
my son had this in his basket , just been sent an offer from the seller 14%, off 44.90us dollars, contacted seller to cancel mine.
For those wanting to see the internals. The tuner section is soldered shut so I may have to use a can opener to see inside.
A very clever board design to minimise the CA components, screws and sealing (only four, plus one nut on the F-plug to keep everything together).
Instructions/menu in Russian so tread carefully to convert to English.
One worrying feature is the satellite database is limited, only Eastern from UK (unless I'm missing something).
Updates are apparently only available via direct USB loading, anyone have the link to more modern firmware ?
Useful fotos, thanks. :Y
Firmware same I think......using RAMF 'ramf v1.17.15.apk'
Satellite database can be deleted then add your own, albeit manually but easily done..
Any one else's turned up yet and have you tried it out, mine should be here in few days
