Fibo Orginal Multifeed Holder?
no doubt about what you said.
Simpel a gregorian type is make by the small dish in front when you make a second lnb as on the picture its not a gregorian type for that lnb. Bud a normal dish.
The gain and corner from a normal dish is lower than a gregorian so the effect is as a normal simpel dish for that second lnb.
Thats it.
some of the toridial 90 dishes,has a design fault,and gain wining is not so good like it should be,when i take a signal meter,the gregory 55 cm brings 0,5 -0.8 db more,gain winning then the smalest gregory with 55 cm!
for most,of the satelites t 90 is enough,but,for optimal results the antenna must be optimeized !
i dont like toridial,the material quality is to flimsy,and when hail is coming you can put the toridal into the trashcan!
a old gregory ,or other types,of old school antennas,are masive enough!
Visiosat Bigsat is the best multisat antenna today.
Really?
Why do you think that is so?
I really like that new Visiosat too.
the quality of this antenna is much better,and not so thin then on the toridial!
but the price is very high 400€
no its only 159 euro from Olbort.at
,dont forget the delivery coasts,inside europe,the are very expensice for antena shiping!
also i was thinking there was difrent visosat modells avalible,one cheaper,and the other with higher price !
The Visiosat Bigsat dish quality seems to be excellent.
You can buy a normal Bigsat and apply a Multifeed holder for 3 LNBs or you can buy the Bigsat2 which already is a Multifeed antenna and put 8 or more LNBs onto it.
The first one should be around €120 and the other one around €170.
VISIOSAT BIG BISAT SMC-Multibeam Sat-dish
169,00 Euro incl. VAT plus shipping
Antenna: 910 x 710 mm
Frequency band: 10.7 ~ 12.75 GHz
Antenna gain: ca. 35,7 dB +/- 0,3 dB (@ 12,7 GHz)
width beam @ -3dB : 2.4° G/T @ 12.5 GHz : 15 dBK
Efficiency: > 70%
Elevation: 10° - 80°
Reflectormaterial: SMC
Colour: white
Weight: 9 - 11kg (depending on the extra LNBs)
Here is a pic with 8 LNBs
Nice!
Seems that even 10 LNBs would work okay.
Back to the topic.
Who has an idea whats received within that single extra LNB (see the pic linked to satlex)?
