filter lav > abc 4T2
anto@
dish 180 laminas 4 feed ku c lin c circ ka tbs 6983 tbs 6903X tbs 6522 JPC positioner
italy
Good morning
someone help me to insert the video filters ( Lav ) in the 4T2 program
after several years I managed to make it work again, and I understood why it didn't start, in the photo I'm watching a program and my CPU is at 95%
even if the PC is from 2016 it is still a 3.8 I5 with a 4GB video card with which I can see all the classic channels, using different players the CPU is very low, if someone helps me where to safely download the Codecs and then in which folder should be installed
thank you very much
just install and the codec should appear in the menu
I have already installed the lav filters on my PC, only that when I go to look in 4T2 as you can see in the photo they are not there,
while with alt dvb I see them and can make the choice
I thank you
No show in Available decoders ?
NO
That old version 0.10.5.5 without support LAV
where do I find the new version??
Thank you, I'll try tomorrow should I uninstall the current one? I have to close now I thank you
here I am
the version I have installed is x 86
the one you sent me is an x 64
I uninstalled x86
I installed x64 on boot
It immediately gives me an error and the player doesn't start
so I uninstalled x 64 and reinstalled x 86
which works with the CPU always high (only if I have more than 2 active channels)
Can you tell me the reason for this error?
Thank you
Can you give me an explanation why I can't get the 4T2 to work in the 64 bit version
while the 86 one works?
my pc is a 64
Thank you
A PRO (P) license is required for the 64-bit version. This is only given to people or firms who purchase the complete device with software.
thank you for the clarification
hence the various photos I see on the forums where the 64 version is used Does the person posting the photo have a PRO license?
I can't say it. I have a Pro License. It might be possible to do it without a license and not watch the stream directly, but first record it with another player and then import it into the 4T2
