Razor
Retired Mod
- Ireland
OK ...If you can go to Dudez or the Den and download The latest TMB file from the Conax section ( TMB 2.6 ). When you unzip it you will find two folders, one is the TMB file the other is the latest TMB editor which has a TIT card programmer built in. It is by far the best I have seen , it can do it all and is very quick. It also has an inbuilt TiT card tester.
When you first open the file it will be set to EDITOR, but there are 5 words across the top, they are.
FILE.....EDITOR......CARD MENU.....PROGRAMMER........ABOUT.
Move your mouse over programmer and click it you will fine 5 options write hex, write eep, erase Tit , write Tit, and lastly TEST Tit.
Have a look and see how you get on.
