Horizon HDSM USB - Latest Firmware and software
Yes, I understand.
I posted the same information previously.
I just wondered if anyone knew of a 28.2E H-H DVB-S Tx that wasn't listed or common knowledge.
I might back up my STB's install info, do a blind scan and report back if there's any positive result.
I'm just trying to push out the time when my Horizon V3 USB DSM will be relegated to a rather expensive door-stop!
There arent any - even the feeds up around 12500-12700 tend to be DVB-S2 these days.
Hi All,
I'm not sure if I'm posting this in the correct post...!
But, I'm looking to replace my HDSM V3 USB as it's becoming obsolete, as discussed previously.
Would anyone have experience with the GTMEDIA V8 DVB-S2/S2X Signal Finder (with 3.5" LCD)?
They're available on ebay from €55 upwards.
I did have the GTMedia GTC Android Combi box before. It was a bit of a pain to setup and I wasn't impressed with their s/w updates to fix obvious functional issues.
Or maybe someone could recommend some other low-cost S2 sat meters, as I can't justify spending too much!
I'd appreciate any useful feedback.
Many thanks in advance.
Hi All,
Ive got a similar but much older version of that branded Dymeco. Utterly useless on any day with the merest hint of sun as the screen is totally unreadable. Ive given up on mine & gone back to an old satellite receiver with a small tv
Hi, can we load the transponder list onto HDSM USB/Plus using SatEdit if it is in .hex format? Or does it have to be .lst thank you
hi i was in same problem with my horizon meter i could not get softwear so i just made a custon carrier and it works try this you can put it in on meter no fuss iput in 11307 h 27500 23 for freesat astra
Big thanks to Peyu75 he made up a new list for my Horizon V3 USB.
It's for 28.2 , 19 E
If anyone wants it I can upload it here.
Hi Teddy99,
I have the same meter.
If you could upload the file it would be appreciated.
Thank you :)
Hi
Im looking for the an updated hex or list file for the Horizon meter,
Also , it seems I'm unable to send PM's , is this feature disabled for new users?
My meter has lost the last Astra 2 Transponder, If someone has an updated file for the HDSM USB, it would be much appreciated if you could share this please. I tried to create it manually but to no success.
I am in Spain and I have the same problem.
I have an hdmi usb I liked this meter but I have had problems editing the sat file.
I did have some success with the custom carrier on the meter.I also have a problem with 13 d east.
hi guy s can anyone help updating
V3 USB HDSM
ive tried files from 21/9/23 from here but they dont work .
thanks john
Contact member Peyu75 on here, he's an expert on these meters and can write you a software upload for the satellites of your choice. He'll also send you the 'satedit' program you need to install it.
