markalmond
- awilsat
- london
Both vertical and horizontal tps aren’t locking the signal and I don’t think you can update the tp manuallywhich TP ?
Hi,hi , can someone help, i have Horizon hd s2 but from today 3/8/22 the Turksat 42e tp has changed , tried to update the tp manually but no luck
Hi thanks for your reply ,the tp is 11096V/240 i brought this meter recently just wondering if its possible to update the tp manually.Hi,
Can you confirm the frequency of the Tps with the issue? You can check in spectrum mode etc.
As a short term fix you could use custom tp option. Türksat 3A/4A at 42.0°E - LyngSat
A recent update on Flysat suggests that transponder is no longer activeHi thanks for your reply ,the tp is 11096V/240 i brought this meter recently just wondering if its possible to update the tp manually.
Hi, Unfortunately you cant update pre-loaded Tps on the HD-S2, you can only change/edit the Custom ones such as Custom1 S2, Custom1 S1 etc . Do you know if you have any custom lists loaded on meter you can try? Originally updates were loaded via the Horizon website which has now gone.Hi thanks for your reply ,the tp is 11096V/240 i brought this meter recently just wondering if its possible to update the tp manually.
Hi , i really appreciate your effortsHi, Unfortunately you cant update pre-loaded Tps on the HD-S2, you can only change/edit the Custom ones such as Custom1 S2, Custom1 S1 etc . Do you know if you have any custom lists loaded on meter you can try? Originally updates were loaded via the Horizon website which has now gone.
I have attached least file from horizon I have and some others that might help.
These is some third party R&D software that can create own Tps but only to list 1 and I'm informed this software can cause some issues with meter so has to be used with caution.
you could also try this s2 list which may still have a working tpHi , i really appreciate your efforts
Hi, which file are you having an issue with?Hi . I'm trying to load the file on HD-S2 but i keep saying invalid data file, I'm not quite sure if the file or loader is wrong.
your help is much appreciated
This one https://www.satellites.co.uk/forums/attachments/uk-s2hd-custsats-list4-zip.144307/Hi, which file are you having an issue with?
Hi, the below file saying invalid data
Hej Peyu75, dla ułatwienia pisze po Polsku, mieszkam i ustawiam anteny w UK. posługuje się miernikiem Horizon hdsm usb i nie narzekam i klienci również Mam wgrane satelity Hotbird oraz Astre. Tylko wszystko stare, czytam i widzę iz jesteś tutaj guru który robi czary mary i potrafi wszystko. Mój miernik ma oprogramowanie dość stare z 2011 o numerze V1. 045B czasami coś szwankuje. Tylko teraz mam prob posiadam maca czy da się przez niego jako wgrać wszystko nowe. Pozdrawiam.Ok, I'll make a list this weekend.
are you sure this is a HDS2 not a HDSM as file loads ok for me?Hi, the below file saying invalid data
ok thanks, i will have another lookyes its HDS2 mate
