how to play dvds on the dm8000
onit123
ASBO Club Member - Persona non grata
dreamboxTriple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes.
woking
I am trying to play dvds BUT NOTHING HAPPENS what should I do I put them in the dvd slot and then nothing does not play does not even play music I try to burn videos recorded to a dvd and then that does not work ever I look in the instructions booklet nothing in there to help
To play your bought or rented DVDs, you need the file attached. Place in /temp and install. for the Nabilosat images, Green button, Yellow Button then Manual Install IPK package
Thanks for this addon it worked for me only problem now is that the movie stutters all the way through the movie any idea wot this problem might be?
Hi all,
I have installed this file and I get a picture now but no sound, I also get no sound watching a .ts file on my hard drive imported from my pc. I am using optical link for sound, will test with phono leads later to see if it is a output problem with optical.
Any other ideas?
I had similar problems with DVD movie freezing.
Using Nabilosat Enigma2 Black Hole v0.11 in flash
(enigma2-plugin-systemplugins-fan-ctrl_0.3.2-20090407_mipsel, andlibdvdcss2_1.0svn20080519-r0_mipsel.ipk)
and
DVD recorder Samsung sn-s083a
HDD Seagate 320 GB.
When I used sata>sata (near DVD drive position) connection DVD movies froze and Nabilosat device manager could not detect my DVD recorder.
Switching to usb>esata (in front of PSU) solved all problems no freezing and device manager detect DVD recorder. No overheating issues, I have original fan installed.
Hope this helps :)
chiefsausage said:
Hi all,
Any other ideas?
I had similar problems using an optical link and now use a RCA cable and that works fine. The optical ink seems to have a two stage fit and the RCA cable would not work with the optical link fitted to my A/V amp. I also use the digital output from my TV to my A/V amp.
The DVDs play fine with BH v1.1 with just the libdvdcss2 file installed. Using Barry Allen seems to interfer with media playing so I only use BH v1.1 now
I've upgraded the image on my DM 8000 to Nab 0.12. My SATA DVD drive is not working. When I go into BP/Setup/Devices Manager I the the following message.
DVD DRIVE:Not Found.
Any ideas.
