I may have been diddled. - Cat5E weight
Channel Hopper
Staff member
UK
I've just received two packages of Cat5E cable, allegedly 300 metres each, though one is decidedly lighter than the other.
Rather than pull them out of the boxes they came in - no reel - and walk up and down the garden with a measuring stick can somebody offer an approximate weight per 100m (or 1km ) so I can challenge the 'lighter' supplier.
Last time I dealt with this stuff it was about 3kgs per 100m if it helps.
Thanks in advance.
I see about 34 pounds per 1000 feet on most CAT 5E spec's I run across. Or 15.42 Kilograms at approximately 300 metres of cable.
So you should be around 15 Kg for the cable, plus the box/container weight.
https://www.prioritywire.com/specs/Category%205E%20PVC%20Shielded.pdf
That does sound excessively heavy for the stuff.
Is the cable you work with specified for outdoor use ?
Yes and it's shielded.
