I need help with LNB HOLDER
Emiliano de
I don't have specific settings.
ALGERIA
I have LNB HOLDER and I want to receive signals from two satellites simultaneously: Eutelsat16E and Hotbird13E. How can I do this given the short distance between them? Has anyone used this method before with this?
What size dish, do you have?
Any dish diameter larger than around 60cm can use separate LNBs side by side for 3 degree reception.
This holder is not suitable.
Here is a better way for an 85 cm off-set dish
Well, Algeria is a big country, but a rough calculation for a ~85cm dish would give a needed LNB-distance (heart to heart) of about 4.4cm, I think.
The shown multifeedholder would have a minimum distance of about 6.8cm?
Apart from that, the one LNB should be positioned clearly higher than the other LNB; rough estimate of 16-23 degrees multifeed tilt of the multifeedrail. That is something to consider too: does the multifeedholder allow this?
Greetz,
A33
I used a 3 degree monobloc for that combination, nice easy solution.
