magic cam dead?
mr_boyson
A friend recently bought a second hand echostar receiver with magic cam and asked me to upgrade the cam for him. I have the matrix revolutions cam.
When I insert the magic cam into my receiver (manhattan) it is not recognised. I tried it on the echostar and it is not recognised there either.
When i put the magic cam into one slot and the m/rev cam into the other slot, with both receivers no cams are recognised. the m/rev cam alone works fine on both receivers.
I tried installing the mr drivers on a laptop to see if that worked but it didnt recognise the magic (well it didnt even recognise my working m/rev cam - so no real surprise, especially after reading various threads about programming with a lappy).
So getting to the point..... could the cam be dead? Or shall I take the risk and buy a CAS2 interface, and will that enable me to "re-initialise" the magic cam.
Any feedback greatly appreciated.
Thanks!!
CAS 2 worth a try m8.
thanks for the reply sonic1.
before i go and splash out 50 odd quid on a cas2 is there anyway of testing if the cam is dead?
was looking at maybe buying the cas2 plus, if I know i can get the cam working. anybody had any experience with these?
thanks
Do you know anyone with a cas 2 or 3 that could check it for you.
If not send it to me and I will check it for you.
Pm me if you want.
cas fifty cam 30 40 its a good investment it will program and reinitialize most cams
sonic1: no I don't know anyone with a cas 2 or 3 :-( thanks for your offer, I will pm u if I get stuck!
wolfav: I was thinking the same, "cas2 plus" at 50 beats a new cam at 30-40. will allow me to prog lots of different cams (I just bought a dragon to go alongside my mrev). Only prob is if the magic cam is dead then 50 is a bit of a waste if a new cam at 30-40 will fix the prob......
