Motor Settings.
For example for sometime BeinSports on 7.0W was working then after sometime I changed the channel and changed it back and lost beinsports.
Check with lyngsat.com, and kingofsat.net, to see if you have the correct channel information. On lyngsat.com there are maps that show the approximate dish size required, for your area.
Look on the right hand side, under the Beam heading, and click on the link.
Okay so let's say I've set my Gotoxx Latitude and longtitude, I am connecting only with 13Degrees and 19Degrees.
The 13 degrees hotbird is actually on my 0 degrees, meaning when I hit drive to 0degrees, it is good for hotbird. So my 0 degrees is hotbird, what can I do so I would be able to lock on other satellites? ( I am locking on Hotbird and astra 19 successfully.)
Actually '0' Degrees should be Satellite 16East if you are residing in Malta...13 E should be around 2 -3 Degs West on the Motor....But
it's not that critical. Try 28E....should be around 15East on your motor and Nilesat 25 West.
