MR Hex to Dec Key converter
im sure you have been told this is a sat forum not a cable forum check rolfs reply to your other post to get some linkgood luck mambatta
Generic, it will convert a hex string to a decimal string.
rolfw said:
Use this if you need to add your keys by remote control, will convert the Hex keys to Decimal for insertion.
Thanks for this wonderful little utility. A Great help for me, should I need to update my Predator keys. Cheers!
i've try it but it didn't work
i need to enter the PP,Idand the code in my reciever and i don't know what is the first two
the other problem that there is V-Code, N-Code in my reciever which on i have to choose
thanks for help
How do i use this to add my keys by remote control.
thank you for all.
Just convert the hex numbers to Decimal and you should be able to enter them, some receivers do allow for hex numbers though.
