Yes, I know, that's not what I meant.
However, I'm on the edge for Saorsat which is available on the EUTELSAT KA-SAT 9A and is a narrow-band satellite with a footprint on Ireland, of which I'm on the coast.
The point is that the multiswitch is unlikely to deteriorate the signal much, only dampen it slightly (at worst).
As long as the noise floor of the multiswitch is below the noise level of the signal coming from the LNB, the STB will manage compensate by amplifying the incoming signal before A/D conversion (after the tuner).
Therefore, if you have reasonable signal before inserting a multiswitch, you should have one after as well. (Unless there's something wrong with the multiswitch.)
Do you have measurements on the C/N ratio of your current reception? Do you know how "fringe" you are?
If you do have problems getting enough signal, getting a larger dish will make a much bigger improvement than trying out different multiswitches.
Yes, I'm just not sure about the Goobay brand. Whether I pay £70 for it, or about another £40 for the EMP which is more recognised is causing me the dilemma. The EMP has a 4 yr warranty whereas the Goobay I believe has a 2yr warranty.
The EMP MS9/8PIU-5 V10 is EUR 99 at satshop.tv.
Shipping is normally something like EUR10-13 from them.
EMP-Centauri PROFI CLASS Multiswitch MS9/8PIU-5 V10, 99,00 EUR - sats
(I bought mine there some years ago. You can probably find it elsewhere, but avoid Satkontor - they have their inventory mixed up sometimes and send you e.g the basic line when you order the profi line. I've had this.)
