- A little less analogue, and a lot more crap.
- UK
I wouldn't have known the colour......... and little blue lozenges for endurance .....
why would it be a problem to have threaded rod as opposed to no thread - its only the elevation angle - once set, its set, surely it doesnt matter if its threaded? does it....Problem is the total length is ok but the threaded part is too long .
You must buy a much longer bolt so the shaft is equal to the original and cut the overlength
I have used it before now, never had a problem to be honent..thanks mate - so its fine to use threaded rod, i got the impression from some posts here, that it needed to NOT be threaded in the middle like the original bolt was...smooth until 1 inch from the end.
M12 is 12mm, your bolt is 12.5mm you said which would be 1/2"found this - sounds perfect
hxxps://www.ebay.co.uk/itm/M12-PART-THREADED-HEXAGON-HEAD-BOLTS-NUTS-HIGH-TENSILE-GRADE-10-9-BLACK-SCREWS-/183602341401?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l49286&mkrid=710-127635-2958-0
160 or 170mm length - smooth but includes 36mm thread at the end....wish there was a 12.5mm option.
Which is why an "Imperial" 1/2" UNC bolt is required!M12 is 12mm, your bolt is 12.5mm you said which would be 1/2"
Took you long enough - he posted that last night!ive just found @cokeaddict link further up this "thread" lol - thanks
PS: isn't it ironic that "the land of the free" used - and still does" - "Imperial" measurements!
No two ways about it - there really are a lot of nuts on eBay!... and no nut with it .. but there are nuts in the sellers other items ...
