AtOM13
- Sedea 80 cm, 1w 13e 19.2e Inverto black ultra LNB
Laminas 150 motorized 47.5w to 76.5e Megasat Diavolo + scalar ring
Channel Master 1.8m
- South France, North of Marseille
I see. In fact, LNB has not focal point but phase center. The main reflector (in your case, CM 120) has a focal point. SUB has 2 focal points.LNB focal point
Whilst it is not absolute, most domestic Gregorian satellite systems will have the faces of the two reflectors more or less parallel to each other (since it keeps the feedhorn from creating a shadow) Can you take a picture (far away) of the side on view ?Ok, lean is corrected.
Still at 80% SQ on 4.8e with the weakest frequency ( 11747 V ) without Fibo.
Haven't time to check performance with Fibo, but I take another picture with Fibo Sub and feedhorn, LNB focal point is 14cm from the middle of the subView attachment 157833
Mine is a motorized prime focus dish. The dish elevations change with lnb adjustments.
This is too rude. Isnt the topic about dish alignment and did i talk about ships? Where in the rules does it say one cant also forward his challenge on same topic under discussion but all should be about the one who begun the thread?I don't understand what you mean, with that sentence. What kind of LNB adjustments, for instance?
I think you'd better open your own thread, for your question. Not neat, to hi-jack @AtOM13 's thread for that.
Greetz,
A33
This topic is about AtOM13's dishes. As your issue appears to be different to those in this thread (e.g. different type of dish) it would be more appropriate to start your own thread rather than continue in this one.This is too rude. Isnt the topic about dish alignment and did i talk about ships? Where in the rules does it say one cant also forward his challenge on same topic under discussion but all should be about the one who begun the thread?
