- A little less analogue, and a lot more crap.
- UK
Annoyingly, the FM reception is fine, plus all the confifuring settings do have an effect on the reception, so its not the stick.
A 2m antenna should work reasonably well - I was getting fairly good Wxsat signals on my 145MHz dipole last weekend. Signal levels were down a fair bit as I hadnt got the wxsat amp in line but should work ok for testing. You havent snapped the central pin off the dongle antenna connector have you - I did that on one of mine and knackered it - Im using the screw on NESDR Smart ones now - they are a bit more expensive but also more robust.
