steo69 said:I've a Hyundai 1000ir decoder and a MM 1.04. When I open the CAS info section it displays DREAMLOAD but there's absolutely no way in proceeding to the next menu "PREPARE FOR LOADING".
Anybody help me?
Thanks,
Stefano from Italy. O-no
john_graydon said:Hi Stefano
You should be able to load software when its in dreamload. What programme are you using to load software. Im using Dream. (Dreamload) Cant remember where i loaded it from. The problem happened me too it wouldnt connect. until i got it to dreamload. John
try another loader programme as i suggestes earlier. DREAM one is the one I used. this one worked for me. Try again and again dont give up you will get there eventually. Try this againsteo69 said:I'm using MAGIC MODULE LOADER. On the programmer the red and the yellow leds are always on. The green one is off. And there's really nothing to do to get it on and have access to programming.
HELP!!!
