new Bosnian package in T2MI
Status
Not open for further replies.
Do you have any other receivers that can lock the Bosnia transponder?
No unfortunately not, I've just discovered setting the symbol rate to 0 will show a signal lock even when the transponder isnt strong enough for a lock so I gather 40% signal quality isnt enough.
Thanks for everyones help
There is a receiver (not enigma2) that has no problem finding this frequency
and which indicates all the parameters of reception,
the openbox S3mini HD ( or S3Mini II HD or S3 CI II )
it is not DVB S2X and not UHD but that is not really important at the moment.
Its only problem is that it is difficult to find.
I have an Octagon SX88+ SE and no problem with the Bosnian transponder. Watching O Music regularly.
I guess your signal is indeed too weak @mikeisyou
mikeisyou has a signal problem - not programs,
delete all transponders from the 33E and have the receiver put in lockable transponders from BlindScan (also enable MTS to find 12646H) and post there what transponders are available in your area
I gave it another try and have it working now on my Dreambox DM920.
Maybe the attached document about my config will help others.
No problem here with this Trans/P.
Using Octagon SF8008.
Hello guys
I have DM920UHD, with newenigma2.5 and multistreaming tuner, 9,5 db strong signal, lock on 11444/17500/
Edited satxml, lamedb, scanned and i got famous channel "11444H SID 0xfa1"
Here is my Astra -sm log:
root@dm920:~$ astra --analyze http://localhost:8001/1:0:1:FA1:190:0:14A2CB3:0:0:0:
May 13 08:07:10: INFO: Starting Astra SM 0.2
May 13 08:07:11: INFO: Bitrate: 0 Kbit/s
May 13 08:07:12: INFO: Bitrate: 0 Kbit/s
May 13 08:07:12: INFO: PAT: tsid: 400
May 13 08:07:12: INFO: PAT: pid: 4096 PMT pnr: 4001
May 13 08:07:12: INFO: PAT: crc32: 0xC2D15836
May 13 08:07:12: INFO: PMT: pnr: 4001
May 13 08:07:12: INFO: PMT: pid: 8191 PCR
May 13 08:07:12: INFO: DATA: pid: 4095 type: Private PES, ISO/IEC 13818-1 (0x06)
May 13 08:07:12: INFO: DATA: descriptor: 0x7F0411000000
May 13 08:07:12: INFO: PMT: crc32: 0x88DFA233
May 13 08:07:13: INFO: Bitrate: 30 Kbit/s
May 13 08:07:13: ERROR: CC: PID:0=1 PID:4096=1
May 13 08:07:14: INFO: Bitrate: 30 Kbit/s
May 13 08:07:15: INFO: Bitrate: 30 Kbit/s
May 13 08:07:16: INFO: Bitrate: 30 Kbit/s
May 13 08:07:17: INFO: Bitrate: 30 Kbit/s
May 13 08:07:18: INFO: Bitrate: 30 Kbit/s
May 13 08:07:19: INFO: Bitrate: 32 Kbit/s
May 13 08:07:20: INFO: Bitrate: 30 Kbit/s
root@dm920:~$ astra --analyze "t2mi://#t2mi_pid=4095&t2mi_input=http://127.0.0.1:8001/1:0:1:FA1:190:0:14A2CB4:0:0:0"
May 13 08:07:31: INFO: Starting Astra SM 0.2
May 13 08:07:32: INFO: Bitrate: 0 Kbit/s
May 13 08:07:33: INFO: Bitrate: 0 Kbit/s
May 13 08:07:34: INFO: Bitrate: 0 Kbit/s
May 13 08:07:35: INFO: Bitrate: 0 Kbit/s
Lamedb:
- Astra Slonik Mod
log.set({ stdout = true, debug = true, syslog = "astra", })
semtel00 = make_t2mi_decap({
name = "SEMTEL c00",
input = "http://localhost:8001/1:0:1:FA1:190:0:14A2CB2:0:0:0",
plp = 0,
pnr = 0,
pid = 4095,
make_channel({
input = { "t2mi://semtel00", },
output = { "http://0.0.0.0:9999/semtel/c00", },
semtel15 = make_t2mi_decap({
name = "SEMTEL c15",
input = "http://localhost:8001/1:0:1:FA1:190:0:14A2CB4:0:0:0",
plp = 0,
pnr = 0,
pid = 4095,
make_channel({
input = { "t2mi://semtel15", },
output = { "http://0.0.0.0:9999/semtel/c15", },
Satxml:
<transponder frequency="11443000" symbol_rate="17500000" polarization="0" fec_inner="3" system="1" modulation="2" />
<transponder frequency="11444000" symbol_rate="17500000" polarization="0" fec_inner="3" system="1" modulation="2" />
userbouquet:
#NAME Dasto Semtel
#SERVICE 1:0:1:FA1:7FE:190:0:0:0:0:http%3a//0.0.0.0%3a9999/semtel/c00:O Kanal
#DESCRIPTION O Kanal
#SERVICE 1:0:1:FA2:7FE:190:0:0:0:0:http%3a//0.0.0.0%3a9999/semtel/c00:UNA TV
#DESCRIPTION UNA TV
#SERVICE 1:0:1:FA3:7FE:190:0:0:0:0:http%3a//0.0.0.0%3a9999/semtel/c00:NOVA BH
#DESCRIPTION NOVA BH
#SERVICE 1:0:1:FA4:7FE:190:0:0:0:0:http%3a//0.0.0.0%3a9999/semtel/c00:BN TV
#DESCRIPTION BN TV
#SERVICE 1:0:1:FA5:7EF:190:0:0:0:0:http%3a//0.0.0.0%3a9999/semtel/c00:O Music
#DESCRIPTION O Music
#SERVICE 1:0:1:FA6:7EF:190:0:0:0:0:http%3a//0.0.0.0%3a9999/semtel/c00:OBN
#DESCRIPTION OBN
#SERVICE 1:0:1:FA7:7EF:190:0:0:0:0:http%3a//0.0.0.0%3a9999/semtel/c00:N1
#DESCRIPTION N1
#SERVICE 1:0:1:FA8:7EF:190:0:0:0:0:http%3a//0.0.0.0%3a9999/semtel/c00:TV SA
#DESCRIPTION TV SA
#SERVICE 1:0:1:FA9:7EF:190:0:0:0:0:http%3a//0.0.0.0%3a9999/semtel/c00:TV Prijedor
#DESCRIPTION TV Prijedor
#SERVICE 1:0:1:FAA:7EF:190:0:0:0:0:http%3a//0.0.0.0%3a9999/semtel/c00:Vikom
#DESCRIPTION Vikom
#SERVICE 1:0:1:FAC:7EF:190:0:0:0:0:http%3a//0.0.0.0%3a9999/semtel/c00:RTV Cazin
#DESCRIPTION RTV Cazin
#SERVICE 1:0:1:FAD:7EF:190:0:0:0:0:http%3a//0.0.0.0%3a9999/semtel/c00:RTV USK
#DESCRIPTION RTV USK
#SERVICE 1:0:1:FAE:7EF:190:0:0:0:0:http%3a//0.0.0.0%3a9999/semtel/c00:RTV BPK
#DESCRIPTION RTV BPK
#SERVICE 1:0:1:FAF:7EF:190:0:0:0:0:http%3a//0.0.0.0%3a9999/semtel/c00:Herceg TV
#DESCRIPTION Herceg TV
#SERVICE 1:0:1:FB0:7EF:190:0:0:0:0:http%3a//0.0.0.0%3a9999/semtel/c00:ProTV
#DESCRIPTION ProTV
#SERVICE 1:0:1:FB1:7EF:190:0:0:0:0:http%3a//0.0.0.0%3a9999/semtel/c00:Posavina TV
#DESCRIPTION Posavina TV
#SERVICE 1:0:1:3:14B4:2064:14A0000:0:0:0:
I can edit transponder with E-Channelizer, but i don't know wich settings schould i change, can you check please?
Thank you :)
Hello guys
Thank you :)
First of all, you have to ensure that astra-sm is started together with the system OE25, have you fulfilled this?
After the manual scan, you need to manually edit the lamedb (OE2.5 does not support automatic DATA pid detection)
Sure, i edited lamedb as suggested
I just need those infos from Dasto Multistream provider.
"To receive a multi stream you must have a DVB-S2x tuner. E.g. the Zgemma H5.2S has one DVB-S2x tuner in the secondary slot - or - the HD51 with a separately sold DVB-S2x tuner.
Currently in Europe Multistream channels exists on Eutelsat 5 West (France and Italian Channels) and Eutelsat 12 West (Italian Channels).
  • Input stream is a stream number that can have 3 digits. If the code is 2 then you enter: 002
  • The PLS mode can be Root, Gold or Combo.
  • The PLS code can be 6 digits. Some Italian channels have code 8. Then you enter: 000008."
There are a few receivers that do not have problems with scanning the t2mi stream. Among them are octagon, edison os mio and so on. I will post a couple of pictures of the settings before scanning. If you ever want to scan a certain frequency, change the value from 4095 to 4096. This always works, at least for me, on the edison os mio4k plus.
hello Beli1910,
this is great info, but on newenigma 2,5 i can put only 3 symbols, not 4 (4095) like on your pictures.
There is possible to put maximal 255. I can edit it with 095, (doesn't work), 4095 is impossible
Whiche image do you use?
Confuse Multistream with T2-MI
OE2.5 does not support direct T2-MI, you must use astra-sm
After scan
After UPDATE for astra-sm
For your example, your colleague Enosat gave you an answer. I was talking about receivers that have support for such scans. Zgemma is also among them, next to Edison, and Octagon is two or three, as far as I've read.
falconXXL if you have properly modified lamedb you should get this result
May 14 22:19:17: INFO: Starting Astra SM 0.2
May 14 22:19:18: INFO: PAT: tsid: 400
May 14 22:19:18: INFO: PAT: pid: 4096 PMT pnr: 4001
May 14 22:19:18: INFO: PAT: crc32: 0xC2D15836
May 14 22:19:18: INFO: Bitrate: 33812 Kbit/s
May 14 22:19:19: INFO: Bitrate: 37721 Kbit/s
May 14 22:19:20: INFO: Bitrate: 37760 Kbit/s
Status
