Between storms and showers I went on the roof today. I thought the green LED was lit before but it is not now. The cables going into the motor are slightly kinked, probably because the dish has gone beyond the normal range I use. When the weather improves I can buzz them out. However, I put a meter on the output from the receiver (tried both ports) and there is no voltage (either at idle or when trying to move dish).
One other thing I noticed when doing config on the tuner (on screen setup) is tuner 1 is indicated as disabled. If I go in and set up the positioner with coordinates, etc. and save it tuner 1 still shows disabled. Tuner 2 looks OK but no dish movement.
Edit.
I connected a 12V DC (1A) source to the coax and found, initially, the LED was lit green before going amber. I could not operate the motor using the buttons. I was going to do a reset but rain started.
Edit.
