New flash images with USB support out
EDW
New images out today for flash with usb support. Usb drive takes var files.
Briefly:
Load the main file (.kim) using KCC3.1
Extract folder 'Stick V1.1 etc. on to formatted usb stick (i used Fat32) about ten files showing NOT one big one.
Insert usb in to front slot.
Boot box
Set up wizard as normal, network settings working easily. Nameserver ip is router ip (for me).
Channel settings, use Dreamset 2.20 and set path to the Settings file on the usb stick, after it uploads box will want to reboot but this will result in channel list favs being lost so a hard reboot is needed instead of enigma reboot so off at the back of the box and then power on again. May need to experiment with this a bit.
FTP to box and stick is best done using latest version of Dreambox Control Centre.
Emu, load the key by hand using ftp, file needed is camd3key for Camd3.
Nice web interface to try out.
Change channel slowly, zapping fast may cause green screen, go gently.
ITV HD is working fine but you must edit the lamedb file as normal. Luxe TV no picture still.
Thanks to Team Duck Tales AFF and all support teams.
