New NS2000 (NS3 / NS4) thread
Just found the line config in the database that was on the unit when I received it.
Moonbase asked for this info.
Finally managed to get an Ns3 channel cleared.
Spent a week trying, using an Alitonika at40 asi usb , tsteader , and the rainbow tool.
continuity errors in ts reader but link margin looks ok. something else causing it? is it noticable when watching?
Never noticed that . Pictures were fine with no break up or buffering.
Managed to clear 3 of the 6 programs in the mux , of the other 3 , 1 was tandberg encryption and the other 2 returned no key .
ive not checked to see if theres s2x feeds. are they the same? i cant get on 10/7e to check bitrates/mux
I have not checked either.
It is definitely a Champions League feed, the picture has just switched to their generic logo.
As it is Novelsat the bit rate will probably be higher than non Novelsat modulations, just guessing on that point though?
The full mux bitrate is just above 93mbps for 5 channels so an approximation would be around 18.6mbps per channel in the mux?
Unless some of the 5 channels are empty carriers in which case the bit rate could be polarised towards the content containing channels?
Nice little biss-2 feed in the NS3 mux today on the "...UCL M2 nonVBR" channel
Other two channels in the mux are standard biss, The UYL one is the Youth League.
guessing the hevc stream is UHD? are most hevc streams in ns mux's Biss 2 and/or director enc?
do you think the EFL league feeding the ifollow streams is exclusively fibre or delivered via a few NS feeds?
The EPL soccer feed is back in NS4 from 100.5E.
This week it has 4 matches in the mux, looks to be a regular at weekends?
Satellite: AsiaSat 5 (100.5E)
Novelsat Modulation: NS4
Frequency: 4178V
Symbol Rate 35294
FEC 19/30
16APSK
Encryption: Tandberg
What size dish needed for 100.5 East c band ?
