New Receiver-Nanoxx 9500
manowar said:
Has anybody tried to load software to receiver via RS232 port? If so then what program makes it possible?
Why use Rs232 when you can go direct to website and install via
ethernet with new updates plus old one if you make mistake - simple as ABC
machno
I am thinking to buy a nanoxx 9500hd after iread about in in sat tele mag and watchd the vedeo of dr dish. Please advise me every body if you recommend this rec, thanks for all .
I am very pleased with mine as i do a lot of recording via USB external hard disk - picture quality is great -10,000 channels and high definition - its only 3/4 size of my Humax 2000 hd. If i had to sell one it would definately be the Humax
machno
machno
Thank you , I think i will get the rec.
machno
thank you macho . I think i well go ahead and buy one then i will jion you in disscussion . regards
Thank you for sharing your comments. I think i willgo for it
@machno
Nanoxx is sometimes late with softwares so you can load ( via RS232) soft from Globo ( this I tried and worked) and from Vantage 7100 ( and with that I still have unsolved problem)
manowar said:
@machno
Many thanks for info - will look into it.
Cheers - machno
new update for nanoxx 9500hd available at _www.nanoxx.com
works well
machno
Please DO NOT post live links to sites off the forum - especially ones with dodgy software on them. This is to protect the forum - any clicks on a link register on the server logs of the site and if they get busted for any reason we could be implicated in promoting dodgy practises.
please teach me step by step which software required for sharing in nanoxx9500HD receiver.
does cccam work in nanoxx. if yes then how to put c line in nanoxx9500
Nanoxx uses Newcam as far as i know and does not work with CCcam. These receivers are next to useless apart than for free to air stuff in all honesty :(
Well, there are emus for that receiver although not frequent and they are far behind some others receivers. However it never crashes, is sensitive so gets channels impossible to get by Octagon 918 or Interstar 890, picture quality is pretty good. To use with cams and legal cards it is pretty good receiver
