Hi Llewhi Tony
Yes, I've seen feeds in the 18.7xx region, especially links from Paris during the outrages there.
On my Triax 1.1M dish,I've used a Norsat 7000 Ka LNB with the XMW or with a 'borrowed' Inverto/Triax Saorsat feedhorn, also a DirecTV SL3, LNB.
My current LNB, a Hughes Band A LNB removed from a Hughes TX/RX assembly, coupled with the XMW feedhorn is proving to be much better at locking (and, more to the point, holding) a weak carrier than my other units showing similar dB levels.
Hi Folks
Just a shot taken off the spectrum display screen, and two shots pics, in this the levels are all good, just before the largest one, Newsnet was -63dBm highest I have seen for a long time[/QUOT
Hi Folks
It's been quite high for some time with me Tony. I'm using the same as Llew, but with the Hughes feedhorn on OMT
Yes, very good conditions tonight. Many Regionals up. Sometimes for me when it's busy, 18557V, the Newsnet HQ TP, drops down to an unlockable signal here, 3.4dB against 6-9 dB with the others.Hi Folks
Agreed Tony, the levels vary such a lot, some feeds can be as high as 15dB and some as low as 7dB with me at any rate.Hi Scopus
Yes agreed they are higher than when the K band downlinks started 2014 by SIS/ITV on Astra 1L, but its the variations
in levels on their downlinks I was also commenting on. The lowest to the highest , across the 18.500 to 18.560 section
can be greater than 7/8 dBm, all using similar uplink kit, and the fluctuations in the carrier levels is also big ref to Ku downlinks, I know they are very much more affected by weather, but even so they do pulse about.
Is the feed still going ? Please llew?18515V, usual parameters for Newsnet feeds.
Fixed OB camera on Abergeldie Castle in Scotland, waiting for it to fall into the River Dee. Heavy rain at present, so stay tuned...
This 'castle' looks more like a Folly to me
Thanks for your reply, looks like my lnb has some sort of problem:-(Yes, it went to SIS card for a while when he moved the camera to a different angle.
The coax has amalgam tape on it, tanken that off already and checked, that's dry, put new tape on.OK Chris, Usual water entry point would be feedhorn to LNB or LNB to cable, but you will have made a good seal there, no doubt.
