1.5m IRTE PF, Invacom SNF-031, TBS6983,
Various L, S, C, X & Ka bits. 1.2m S/X/Ku/Ka Prodelin on Az-El (being refurbished), 1.8m Precision PF with Bullseye Ku LNB or various C & X bits
Thanks to Capitan Unico for pointing out that the craft is now at ~6.8W. The NSSDC TLE had not been updated at the time of this post.
The level is varying a lot with short and long term components of up to 35dB. 12499 RHC is off at the moment. These plots are from 12498 RHCP (on linear feed):
Nilesat 301 has arrived to 10,5°West and start tests for some transponders in analog PAL standard
Frequency's to testing currently:
10758V PAL
10796V PAL
10930H PAL
11219H PAL
11240V PAL
11727H PAL
11747V PAL
11766H PAL
11785V PAL
12169V PAL
12188H PAL
12265H PAL
12341H PAL
12360V PAL
12380H PAL
12437V PAL
12455H PAL
12476V PAL
Today the first carrier tests have begun, at about 10,2°W.
11765,84 H 33MHz
11823,38 V 33MHz
11842,56 H 33MHz
11880,92 H 33MHz
11919,28 V 72MHz
12015,18 H 72MHz
12034,36 V 72MHz
12206,98 V 33MHz
12283,70 V 33MHz
12302,88 H 33MHz
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
