As I'm not able to reproduce the issue myself it's hard to fix it. Can anybody who is experiencing this problem register at xenforo.com to see if there site does the same please.
It's more than one issue.As I'm not able to reproduce the issue ...
No idea chris but getting a security error message when loging out now
Do you get the reply box problem at xenforo.com ?It hasn't altered the reply box problem for me.
Removing compatibility view also removed the reply box. I had to reinstate compatibility view to post this.
I've disabled some plugins can you confirm if this has sorted the issues?
So do I. There appears to be less wasted white space between the topics. I have long railed against this and I am convinced this must surely be a setting alteration somewhere.Here's a (gigantic) forum using xenforo. I must say I prefer their looks, layout and general navigation.
Now if it works, it gave problems to upload the photos, but good and aora ok, so perfect and you do not have to authorize my post a moderator.
Ahora si funciona, dio problemas para subir las fotos, pero bien y aora ok, asi perfecto y ya no tiene que autorizar mis post un moderador.
I'll have to register to find that out. Hang on a bit,Do you get the reply box problem at xenforo.com ?
Not sure they are all turned off at the moment so will need to turn them on one by one to find the culprit.So, @chris , which plug-ins seem to be the guilty one(s)?
